Stops mid wash cycle, no code's, power is ,on does not shut down. Have to pull the plug and then restart. It's older don't now if it's worth fixing.
So it fills and tumbles but then stops? Or drains then stops? Spins then doesn't refill? Need more info about when this happens.
