Had a bad motor on this dryer.Purchased the motor kit WE17X10010 to replace it. I installed the jumper harness that came with the kit to the new motor. Then the instructions say to plug in the dryer harness into the jumper harness. There isnt a dryer harness. My old motor is 5KH26JJ064S. need wiring answers? Also do i have the right motor kit?
If your dryer doesn't have a wide motor plug that was attached to the original motor you'll need to plug the female terminals from the original harness directly to the male motor terminals probably. There are several videos on Youtube about it. That motor replaces many older ones, all instructions may not apply in all cases.
