JoAnninWV
#1 Posted : Sunday, May 7, 2017 8:06:39 PM(UTC)
JoAnninWV
My dryer started thumping. The only way to describe it is that there is a sock stuck to the drum and it thumps when it runs over the sock. HeeHee. It is slow...one thump per turn of the drum.
Belt? Rollers?
PNWDrew
#2 Posted : Monday, May 8, 2017 8:50:21 PM(UTC)
PNWDrew
You need to open the top and see if perhaps a piece of the black mastic is hitting the cabinet or something is stuck to the grooves where the rollers ride at front and rear edges of drum. Pull your filter out and remove the 2 screws that are under it. There are also 2 clips (probably plastic) on the front edge that may be more fun. They can be compressed with thin putty knife or other similar object but I usually pull the whole top forward and it will clear the clips if you are lucky. You can run it with the lid lifted, just take care not to get anything caught if you lean over it. You can turn it by hand at first to avoid running it at speed.
If nothing there you may have a damaged belt as it rotates at close to drum speed.Rollers are small and so spin much faster so the repetition of the thump would usually be faster.
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
Whirlpool Gas Dryer motor overheating - shuts-off (Dryer Repair)
by animateme 9/19/2019 11:59:22 AM(UTC)
Whirlpool Gas Dryer heating intermittently, timer not working (Dryer Repair)
by christyhecht 5/2/2017 10:50:15 AM(UTC)
Whirlpool Gas Dryer screaching noise at first, then stops mid cycle (Dryer Repair)
by SRALPH 12/14/2016 11:40:34 AM(UTC)
Whirlpool Gas Dryer Takes Too Long (Dryer Repair)
by bijalshah01 9/28/2016 5:28:12 PM(UTC)
Whirlpool Gas Dryer Heating Problem (Dryer Repair)
by rinkugaya 9/24/2016 3:17:35 PM(UTC)
Whirlpool gas dryer heating issues/gas smell (Dryer Repair)
by Houseforsaken 8/8/2016 1:24:58 PM(UTC)
Whirlpool gas dryer no heat (Dryer Repair)
by alabamainnevada@yahoo.com 6/23/2015 5:54:15 PM(UTC)
Need Wiring Diagram for Whirlpool Gas Dryer (Dryer Repair)
by ToddErickson 2/2/2015 4:11:08 PM(UTC)
Whirlpool gas dryer only heats for the first 5-10 minutes of cycle (Dryer Repair)
by Peter Wood 9/18/2014 7:28:53 PM(UTC)
Whirlpool Gas Dryer LP to NG (Dryer Repair)
by kyle_8888 4/10/2014 9:49:37 AM(UTC)
Whirlpool Gas Dryer - heat won't stay on (Dryer Repair)
by tubegeek 3/11/2014 1:10:32 PM(UTC)
Whirlpool gas dryer (Dryer Repair)
by jeswon 12/16/2013 6:55:50 AM(UTC)
by miller42 9/4/2013 6:43:14 AM(UTC)
Whirlpool gas dryer too hot (Dryer Repair)
by dorkfart 8/1/2013 6:56:43 AM(UTC)
