Joe Willie
#1 Posted : Thursday, April 6, 2017 7:27:11 AM(UTC)
Joe Willie
Would you believe we spilled clothes detergent into the lint collector slot. The dryer makes an awful noise and the detergent has drained out of the exhaust port. Afraid to run. The detergent must have effected the belt or possibly motor. Looking for advice on maintenance.
Thanks.
manfred63
#2 Posted : Thursday, April 6, 2017 10:01:54 AM(UTC)
manfred63
You will need to clean out the rest of the detergent before using. It shouldn't have damaged anything, but you will be able to know for sure once you remove the lint trap housing to clean it out and to clean the blower wheel. Unplug the dryer first, then look at this video starting at 3:50 for how to remove the lint trap housing https://youtu.be/aFy2tKg3hUA Clean everything out and you should be OK!
Ken's Appliance Repair
Dacor cooktop Spill Protector (Oven Repair (including Ranges and Cooktops))
by riregan 9/30/2017 12:22:32 PM(UTC)
ice maker runs over and spills into bottom of freezer (Refrigerator & Freezer Repair)
by cjsand 1/9/2014 10:08:13 AM(UTC)
Washer drum huge spill. (Washer Repair)
by That One Guy 6/13/2013 9:36:40 PM(UTC)
whirlpool cabrio displays ul code and spills water on floor (Washer Repair)
by dirtman 13 7/29/2012 8:06:36 PM(UTC)
Jennaire burners not working after spill on cooktop (Oven Repair (including Ranges and Cooktops))
by andreaba 6/26/2012 6:08:03 AM(UTC)
Spill Leaked Behind Power Control Board (Dryer Repair)
by Ennyl 5/2/2012 11:17:44 PM(UTC)
Softener spilled in front door glass of washer (Washer Repair)
by Cheryl926 4/12/2012 8:45:10 PM(UTC)
attaching gasket to spill protector around cooktop knob (Oven Repair (including Ranges and Cooktops))
by dkosterl 12/20/2011 8:00:43 PM(UTC)
JennAir fridge icemaker spilling/freezing water (Refrigerator & Freezer Repair)
by Drew 85379 12/8/2010 2:14:18 PM(UTC)
Spilled water on gas range (Oven Repair (including Ranges and Cooktops))
by miyunkim 9/21/2010 4:53:34 PM(UTC)
Tub leaning too far forward causing water to spill while filling (Washer Repair)
by DEZB 5/9/2010 6:54:21 PM(UTC)
Spillover (Oven Repair (including Ranges and Cooktops))
by Bobbie Dudley 2/2/2010 5:48:50 AM(UTC)
remove spill tray on thermador (Oven Repair (including Ranges and Cooktops))
by lindakkreitner 1/25/2010 9:30:38 AM(UTC)
Whirpool Washer Spins And Drains At Same Time Spilling Over Top (Washer Repair)
by potatohead 1/19/2010 2:09:10 PM(UTC)
Continuous Sparking of Ignitors after spilling over control knob (Oven Repair (including Ranges and Cooktops))
by skeet 12/8/2009 4:28:59 PM(UTC)
