Hi Gene,
Wondering if you can help. The Ice maker has suddenly started to become intermittent. It works sometimes, others it wont. The red led flashes twice when the draw is open...when the flap on the left is closed and the door switch is pushed in the led goes out. From what I understand this light should be on constantly.. as it will make ice when it is....when the ice breaks the light it should stop making ice ? Does this mean I need to replace the led control boards? and if so which part number do I need to order?
Thanks in advance
