beazlp67
#1 Posted : Monday, March 20, 2017 9:58:44 AM(UTC)
beazlp67
I am renting a home where there is a dryer that is very old. It is a speed queen. I have taken it apart and cannot find a model number anywhere. The problem started by the dryer blowing the circuit breaker on the fuse box. After testing, it was determined that it was the circuit breaker and that was replaced. The home owner took the dryer apart without marking the wires. There is a box on the top of the motor that is numbered from the bottom up 1 and 6 on the left and 2 4 5 on the right. I found the dryer wiring schematic but do not really understand how to read it. This is my first dryer project. With the way the dryer is wired now, as soon as the timer is started the dryer begins to hum or buzz without the start button being pushed. I'm wondering if it could be a wiring issue. The only identification I can find is a part number on the wiring schematic 54663R1. As of now the dryer is wired with black wires to 1 and 2. These come from the power source and the heating element. Yellow to number 6 which comes from the start switch. Brown to number 5 also from the start switch, white to number 4. There are blue wires from the top of the motor that are plugged into 4 and the slot between the 1 and 6 on the other side that does not seem to have a visible number. Any help would be appreciated.
Bradwell
#2 Posted : Friday, March 24, 2017 3:28:10 AM(UTC)
Bradwell
With such problems, you might want to contact https://euappliancerepair.com/services/dryer-repair/. They have a lot of experience and work really with all kinds of dryers!
beazlp67
#3 Posted : Friday, March 24, 2017 7:31:19 AM(UTC)
beazlp67
Thank you for the information.
Dryer buzzing & getting hot b4 pressing start (Dryer Repair)
by 8yrwhirlpool 1/26/2016 3:00:36 PM(UTC)
Maytag Stackabl Dryer will not start, Makes the dryer Buzzing sound LSE7806ace (Dryer Repair)
by mdmitchell 6/29/2014 11:08:33 AM(UTC)
Gas dryer buzzing (Dryer Repair)
by bobgjr 9/15/2013 11:35:22 AM(UTC)
Whirpool Dryer buzzing. (Dryer Repair)
by jv9908 8/21/2013 9:12:16 PM(UTC)
loud dryer buzzing sound (Dryer Repair)
by man599 8/21/2012 6:22:49 PM(UTC)
Amana Electric Dryer Buzzing Sound (Dryer Repair)
by amanabert 5/12/2012 11:48:31 AM(UTC)
Westinghouse dryer buzzing no start (Dryer Repair)
by 02duramax 1/10/2011 7:03:31 PM(UTC)
dryer buzzing and smell (Dryer Repair)
by aewilk02 10/14/2010 11:15:45 AM(UTC)
by queen 4/11/2010 10:58:02 AM(UTC)
Amana dryer buzzing noizes (Dryer Repair)
by Nick Parkin 12/29/2009 7:40:58 PM(UTC)
GE Dryer Buzzing Instead of Starting (Dryer Repair)
by gumbo2000 1/14/2008 6:02:04 PM(UTC)
