Washing machine goes into wash stops along the way with an error code. it beeps 3 times then flashes once. not sure if im reading this correctly as f0e1 the manual says with that code washer is detecting a load during cleaning cycle, or mechanical friction. Unit is not in cleaning mode and drum appears to spin very smoothly in both directions. any ideas?
Brian
At what point does it stop? Random or always same spot?
it washes for a little bit then stops always in the same spot never makes it into spin cycle Originally Posted by: BrianNstl  Washing machine goes into wash stops along the way with an error code. it beeps 3 times then flashes once. not sure if im reading this correctly as f0e1 the manual says with that code washer is detecting a load during cleaning cycle, or mechanical friction. Unit is not in cleaning mode and drum appears to spin very smoothly in both directions. any ideas?
Brian
