BrianNstl
#1 Posted: : Wednesday, February 15, 2017 10:38:52 AM(UTC)
BrianNstl
Washing machine goes into wash stops along the way with an error code. it beeps 3 times then flashes once. not sure if im reading this correctly as f0e1 the manual says with that code washer is detecting a load during cleaning cycle, or mechanical friction. Unit is not in cleaning mode and drum appears to spin very smoothly in both directions. any ideas?
Brian
PNWDrew
#2 Posted : Wednesday, February 15, 2017 8:07:46 PM(UTC)
PNWDrew
At what point does it stop? Random or always same spot?
BrianNstl
#3 Posted : Thursday, February 16, 2017 5:40:42 AM(UTC)
BrianNstl
it washes for a little bit then stops always in the same spot never makes it into spin cycle
Brian
