agjr200hp
#1 Posted : 8 years ago
agjr200hp
I have whirl pool duet WED9400SW0. The dryer looks normal with all lights, settings, etc. but the start button and the control lock/unlock will not go, just get three beeps. No error codes. The drum light works with the button but not when i open and close the door. Per the manual, it seems like it is supposed to.
thermal fuse = ohm reacts with readings fluctuating from 4 -11
thermistor = ohm set to 20k and get 16 and change (read you should have 10 at room temperature but it is 60 degrees in basement)
I was thinking the door switch and ordered the part. Anyone have other ideas?
PNWDrew
#2 Posted : 8 years ago
PNWDrew
That sounds probable as the triple beep is the sound it'll make if you push start with the door open. Often you can feel bad door switches when you push them, they'll feel crunchy. Or have no discernible click when the switch closes. Try to push it manually while you press start. I think it opens one contact and closes another so wiring around it is difficult.
Good Luck
Whirlpool Dryer Won't Start- Help! (Dryer Repair)
by NikTy15 10 years ago
Whirlpool dryer won't start (Dryer Repair)
by cmarley304 11 years ago
Whirlpool Dryer Won't Start (Dryer Repair)
by jdbell1114 11 years ago
by emontoute 12 years ago
by Turtleman1961 12 years ago
Whirlpool Dryer won't start (Dryer Repair)
by adsch 13 years ago
Whirlpool Dryer won't start - buzzing (Dryer Repair)
by David Mitchell 13 years ago
by gunworks 13 years ago
by patarnotte@comcast.net 13 years ago
Whirlpool Dryer won't start, but hums (Dryer Repair)
by gmreeves2 13 years ago
by JWCL 13 years ago
by moonie777 14 years ago
by zebra47cb 14 years ago
Whirlpool Dryer won't start in dryer mode. (Dryer Repair)
by hol99 14 years ago
