stevenm
#1 Posted : Friday, January 13, 2017 5:16:59 AM(UTC)
stevenm
Hi!
My microwave is not working. Backstory is this. Used microwave after boiling water on range top and blew the diode. (forgot to run vent fan) I replaced the diode and the microwave worked fine for a couple of days. Heated up a plate of food last night and after removing food to stir and heat some more the microwave won't turn on. I can set the timer and the timer counts down but the unit is not running. I unplugged it for a while to no avail. Any thoughts?
Thanks!
Over range Microwave exhaust fan slows (Microwave Repair)
by Mmetzinger 6/3/2023 7:19:23 AM(UTC)
GE Microwave Louder and Not Heating PEB7226SF2SS (Microwave Repair)
by Guest 7/24/2022 9:39:41 AM(UTC)
Change Microwave Bulb (Microwave Repair)
by Guest 6/20/2022 7:26:07 AM(UTC)
GE Microwave Lighting Issue (Microwave Repair)
by HDL 5/5/2022 11:29:53 AM(UTC)
GE Microwave JVM1540DM4 WW - Looking for wiring diagram (Microwave Repair)
by shotgnz 10/19/2021 12:38:16 PM(UTC)
GE Microwave Not turning table nor heating JVM1540DM4WW (Microwave Repair)
by gnieciag 7/14/2021 6:33:35 PM(UTC)
GE Microwave (JE1860BH04) won't heat AND table won't turn (Microwave Repair)
by CoryH 2/17/2021 6:45:11 AM(UTC)
Samsung Over-the-Range Microwave (Microwave Repair)
by smitty121064 2/11/2021 8:14:40 AM(UTC)
GE Microwave tripping breaker (Microwave Repair)
by Bafire0731 2/21/2019 3:08:47 PM(UTC)
ge microwave door (Microwave Repair)
by david habenicht 10/29/2018 11:26:32 PM(UTC)
Samsung over range microwave no power (Microwave Repair)
by toolmaker129 10/25/2018 10:03:29 AM(UTC)
GE Microwave Not Heating (Microwave Repair)
by JIMMIEM 2/3/2018 6:14:54 AM(UTC)
GE microwave exhuast fan won't shut off (Microwave Repair)
by diy_dave54 9/21/2017 7:55:08 AM(UTC)
GE Microwave Start and Quick Start Buttons Don't Work. (Microwave Repair)
by garypatterson 5/15/2017 10:47:49 AM(UTC)
GE Microwave - dead (Microwave Repair)
by bfamily 3/5/2017 2:32:33 PM(UTC)
