s23ayers
#1 Posted : Friday, December 9, 2016 4:26:25 PM(UTC)
s23ayers
My dryer runs but is not heating. Here's what happened.
Top of dryer was rusting so I unplugged it to work on it and there was a big spark. The breakers were not tripped. But after plugging the dryer back in it would run but not heat. Last time that happened it was a blown hi-limit thermostat, I pulled off the back and checked the hi-limit thermostat, the thermal fuse, the operating thermostat, the thermal cutoff fuse and the heater coils. All showed continuity.
So what else should I check?
Thanks,
Steve
s23ayers
#2 Posted : Tuesday, December 20, 2016 3:29:41 PM(UTC)
s23ayers
The problem turned out to be a burnt out connection in the outlet. New outlet and everything works great.
GE dryer runs but won't heat up (Dryer Repair)
by bristles 5/5/2020 5:44:54 PM(UTC)
Kenmore Elite HE3 Dryer runs but won't heat up (Dryer Repair)
by Ives 8/23/2010 2:55:20 PM(UTC)
Electric dryer runs but won't heat (Dryer Repair)
by reallyerica 5/30/2009 1:08:08 PM(UTC)
Maytag Elec. Dryer Runs but won't heat (Dryer Repair)
by pacomt 12/31/2008 4:25:04 PM(UTC)
by michellec107 11/8/2008 6:20:27 PM(UTC)
Gas dryer runs but won't heat (Dryer Repair)
by sblack 10/4/2008 6:54:53 AM(UTC)
GE Dryer runs but won't heat (Dryer Repair)
by JWG 7/25/2008 3:12:04 PM(UTC)
Dryer runs but won't heat. (Dryer Repair)
by John Drayton 6/24/2008 9:01:11 PM(UTC)
Whirlpool Gas Dryer runs but won't heat (Dryer Repair)
by Annamarie 11/12/2007 6:00:24 AM(UTC)
