carpenter83
#1 Posted : Thursday, December 1, 2016 3:23:22 PM(UTC)
carpenter83
dryer runs, just no heat, replaced thermal fuse, wasn't thermal fuse, then replaced operating thermostat.... dryer worked great for about 2 weeks, then no heat again... cleaned everything... do not want to spend another $45 on part to fail again... any ideas?
ThatGuy
#2 Posted : Thursday, December 1, 2016 8:33:04 PM(UTC)
ThatGuy
Groups: Expert
United States
I have lots of ideas, but need a model number to start with.
carpenter83
#3 Posted : Friday, December 2, 2016 4:15:38 PM(UTC)
carpenter83
That Guy, thanks for response. It is 110.62202100
ThatGuy
#4 Posted : Friday, December 2, 2016 8:57:10 PM(UTC)
ThatGuy
Groups: Expert
United States
Yours is fairly simple, heating element, thermal cutoff/fuse on element shell, thermostat, timer, motor start switch and the wires that connect everything up.
I usually start with the power coming in. Make sure you have 240 volts to the dryer. I look over all electrical connections, look for burnt connectors and discolored wires.
Check the heating element, thermal cutoff/ fuse, and cycling t-stat for continuity.
If they and the wiring in between are good check the timer.
timer WP3976582
heating element WP279838
thermal cutoff/fuse
279816
t-stat
3387134
Kenmore Electric Dryer 110.65132411 (Dryer Repair)
by Guest 5/1/2024 5:58:30 AM(UTC)
Kenmore electric dryer model 110.68622700 (Dryer Repair)
by Guest 11/12/2023 6:47:37 PM(UTC)
Kenmore electric dryer won't stay running (Dryer Repair)
by steve37887 10/25/2019 4:52:25 AM(UTC)
Kenmore Electric dryer (Dryer Repair)
by scorpio012 1/21/2018 12:45:44 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
Belarus ginakra 9/21/2017 11:03:29 AM(UTC)
Kenmore Electric Dryer (Dryer Repair)
by johnhb 9/30/2015 7:27:45 AM(UTC)
by johnhb 9/30/2015 7:27:43 AM(UTC)
Kenmore Electric Dryer Won't power up. (Dryer Repair)
by lamarc72 11/19/2013 9:30:31 AM(UTC)
Kenmore Electric Dryer Runs and No Heat (Dryer Repair)
by dadunn1960 3/15/2013 8:14:52 AM(UTC)
Kenmore Electric Dryer - drum hits the top of the dryer. (Dryer Repair)
by willow5000 2/14/2013 9:19:06 PM(UTC)
Kenmore Electric Dryer - Runs but no heat and timer not running (Dryer Repair)
by CapN 12/11/2012 5:31:31 AM(UTC)
Kenmore Electric Dryer cuts off after running 2/3 minutes (Dryer Repair)
by Robert Ferrell 10/14/2011 9:21:09 AM(UTC)
Kenmore ELectric dryer (Dryer Repair)
by Donnadryer 9/11/2011 3:56:16 PM(UTC)
Kenmore electric dryer starts and stops (Dryer Repair)
by missfixit1974 9/9/2011 12:59:29 PM(UTC)
Kenmore electric Dryer won't Tumble (Dryer Repair)
by ohmydryer 9/6/2011 2:09:46 PM(UTC)
