2 Pages12>
douville
#1 Posted : 18 years ago
douville
not sure of the age however refrigerator is not cold and the freezer is working at about half of what it should, not sure what to look at first, did not see the fan in the back of the freezer turning, felt that it should be, have shut it off for now any idea's.
jdman
#2 Posted : 18 years ago
jdman
If the condensor fan motor is not working, you found the problem.
douville
#3 Posted : 18 years ago
douville
the condenser fan does work the fan located in the freezer portion of the refrigerator has not come on do not know what triggers it but believe it moves cold air to the refrigerator portion and circulates the cold air inside the freezer part also believe this may be the problem but do not know how to check it
jdman
#4 Posted : 18 years ago
jdman
With the door open the evaporator fan will not run. You will have to oudh in on the door switch with your finger to see if it will come on or not.
douville
#5 Posted : 18 years ago
douville
tried holding the switch and it does not come on
jdman
#6 Posted : 18 years ago
jdman
Before you shut the unit down and noticed that the fan was not running did you notice ice on the evaporator. You can chech the motor for continuity or you can unwire fan and wire to jumper cord to test. I beleive your motor has gone bad
douville
#7 Posted : 18 years ago
douville
i reached in the freezer part and thru the grate that covers the fan turned it with a round file as it was the handist thing anyway it moved a little and i kept turning it and it started to spin slowly at first than at a faster speed it now is running at i think normal speed maybe it needs a drop of oil or has gummed up for some reason. will run it and see what it does
jdman
#8 Posted : 18 years ago
jdman
Glad you found the problem. Normally though when they start acting like this they are at the end of there life. You might want to order a motor and have it on hand. Then when it quits, you won't be down while your getting a motor. They are not expensive or hard to change out.
douville
#9 Posted : 18 years ago
douville
jdman thanks for your help it is nice to have it running again a new fan has been ordered.
mulnixii
#10 Posted : 16 years ago
mulnixii
the condensor fan is on back or bottom on the outside of the unit the evaperator fan is on the inside of the freezer.
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 11 months ago
Samsung Refrigerator Freezer Model #FJ24J9960S4/AA (Refrigerator & Freezer Repair)
by macdav2022 2 years ago
Refrigerator freezer either too cold or too warm, running continually (Refrigerator & Freezer Repair)
by coolforcats 2 years ago
1985 Kenmore 18 refrigerator freezer went warm recently (Refrigerator & Freezer Repair)
by Guest 3 years ago
Whirlpool Refrigerator Freezer Coils Icing up (Refrigerator & Freezer Repair)
by aarrington 3 years ago
Both refrigerator freezer and cabinet below freezing (Refrigerator & Freezer Repair)
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 3 years ago
KFIS29BBMS03 KitchenAid Refrigerator freezer only gets to 17 degrees, Fridge seems okay at 38 (Refrigerator & Freezer Repair)
by JCohen8008 4 years ago
Whirlpool Refrigerator Freezer Section Intermittently Not Cooling or Making Ice (Refrigerator & Freezer Repair)
by dreeves1822 4 years ago
GX2FHDXVB00 whirlpool refrigerator freezer not freezing (Refrigerator & Freezer Repair)
by Nwhe54 4 years ago
Sumsung refrigerator freezer problem (Refrigerator & Freezer Repair)
by DRJHNJHNSN 5 years ago
Viking 48" refrigerator freezer getting too cold (Refrigerator & Freezer Repair)
by nmunn 6 years ago
GE side by side refrigerator freezer not cooling (Refrigerator & Freezer Repair)
by ReddogRudy 7 years ago
GE Refrigerator freezer and food not cold enough (Refrigerator & Freezer Repair)
by Jerrysing 9 years ago
Frigidair refrigerator freezer cold refrigerator warm. (Refrigerator & Freezer Repair)
by Dennypccc1 9 years ago
2 Pages12>
