2 Pages12>
douville
#1 Posted : Saturday, August 11, 2007 3:16:00 AM(UTC)
douville
not sure of the age however refrigerator is not cold and the freezer is working at about half of what it should, not sure what to look at first, did not see the fan in the back of the freezer turning, felt that it should be, have shut it off for now any idea's.
jdman
#2 Posted : Saturday, August 11, 2007 2:38:52 PM(UTC)
jdman
If the condensor fan motor is not working, you found the problem.
douville
#3 Posted : Saturday, August 11, 2007 3:31:42 PM(UTC)
douville
the condenser fan does work the fan located in the freezer portion of the refrigerator has not come on do not know what triggers it but believe it moves cold air to the refrigerator portion and circulates the cold air inside the freezer part also believe this may be the problem but do not know how to check it
jdman
#4 Posted : Saturday, August 11, 2007 4:15:43 PM(UTC)
jdman
With the door open the evaporator fan will not run. You will have to oudh in on the door switch with your finger to see if it will come on or not.
douville
#5 Posted : Saturday, August 11, 2007 5:27:46 PM(UTC)
douville
tried holding the switch and it does not come on
jdman
#6 Posted : Saturday, August 11, 2007 6:59:06 PM(UTC)
jdman
Before you shut the unit down and noticed that the fan was not running did you notice ice on the evaporator. You can chech the motor for continuity or you can unwire fan and wire to jumper cord to test. I beleive your motor has gone bad
douville
#7 Posted : Saturday, August 11, 2007 8:24:58 PM(UTC)
douville
i reached in the freezer part and thru the grate that covers the fan turned it with a round file as it was the handist thing anyway it moved a little and i kept turning it and it started to spin slowly at first than at a faster speed it now is running at i think normal speed maybe it needs a drop of oil or has gummed up for some reason. will run it and see what it does
jdman
#8 Posted : Sunday, August 12, 2007 6:04:49 AM(UTC)
jdman
Glad you found the problem. Normally though when they start acting like this they are at the end of there life. You might want to order a motor and have it on hand. Then when it quits, you won't be down while your getting a motor. They are not expensive or hard to change out.
douville
#9 Posted : Tuesday, August 14, 2007 8:18:44 AM(UTC)
douville
jdman thanks for your help it is nice to have it running again a new fan has been ordered.
mulnixii
#10 Posted : Saturday, May 2, 2009 2:46:45 PM(UTC)
mulnixii
the condensor fan is on back or bottom on the outside of the unit the evaperator fan is on the inside of the freezer.
GE side by side refrigerator freezer not cooling (Refrigerator & Freezer Repair)
by ReddogRudy 6/10/2018 3:21:06 PM(UTC)
GE Refrigerator freezer and food not cold enough (Refrigerator & Freezer Repair)
by Jerrysing 9/30/2016 6:31:22 AM(UTC)
Frigidair refrigerator freezer cold refrigerator warm. (Refrigerator & Freezer Repair)
by Dennypccc1 9/7/2016 6:50:59 PM(UTC)
Kenmore Elite Refrigerator freezer door replacement (Refrigerator & Freezer Repair)
by jimx375 12/30/2015 7:50:53 AM(UTC)
Whirlpool Refrigerator Freezer Not Working (Refrigerator & Freezer Repair)
by srbr 8/6/2015 6:24:04 PM(UTC)
Refrigerator freezer mystery:too cold (Refrigerator & Freezer Repair)
by atlantis43 11/18/2014 6:27:01 AM(UTC)
Refrigerator Freezer not staying cold (Refrigerator & Freezer Repair)
by ericksonclan6 3/16/2014 4:34:46 AM(UTC)
Refrigerator freezer not staying cold/tripping breaker (Refrigerator & Freezer Repair)
by dlong55 12/15/2013 2:12:40 PM(UTC)
Kenmore top refrigerator Freezer working bottom not cooling. (Refrigerator & Freezer Repair)
by Nelson P 8/22/2013 7:16:15 AM(UTC)
refrigerator freezer (Refrigerator & Freezer Repair)
by carl-761 7/1/2013 4:48:41 PM(UTC)
hotpoint refrigerator freezer not cold (Refrigerator & Freezer Repair)
by bradleymichael 6/28/2013 4:09:18 PM(UTC)
whirlpool refrigerator freezer (Refrigerator & Freezer Repair)
by bisland9 3/12/2013 6:20:47 AM(UTC)
Side by Side Refrigerator Freezer (Refrigerator & Freezer Repair)
by MsEddye 1/10/2013 1:04:09 PM(UTC)
GE Refrigerator Freezer Door Frozen Shut (Refrigerator & Freezer Repair)
by George Ellis 10/27/2012 10:18:40 AM(UTC)
side by side refrigerator freezer (Refrigerator & Freezer Repair)
by nking 10/18/2012 3:48:07 PM(UTC)
2 Pages12>
