A friend's Frigidaire fghb2800lfe refrigerator was delivering only crushed ice. After reading several forums, I determined that the cube/crushed solenoid was probably bad, and ordered a new one.
Upon taking out the old solenoid, and testing it, it was physically locked with the shaft tilted to one side. It was also showing a direct short on a multi-meter (confirmed by applying 120v to the terminals and popping a house circuit breaker).
I tested the new solenoid, and installed it, but it appears that it's not getting voltage.
Any suggestions on where to go next?
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 ![United States United States](/Content/images/flags/US.png) Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
