bbast07
#1 Posted : Monday, November 7, 2016 4:47:25 AM(UTC)
bbast07
A friend's Frigidaire fghb2800lfe refrigerator was delivering only crushed ice. After reading several forums, I determined that the cube/crushed solenoid was probably bad, and ordered a new one.
Upon taking out the old solenoid, and testing it, it was physically locked with the shaft tilted to one side. It was also showing a direct short on a multi-meter (confirmed by applying 120v to the terminals and popping a house circuit breaker).
I tested the new solenoid, and installed it, but it appears that it's not getting voltage.
Any suggestions on where to go next?
ThatGuy
#2 Posted : Monday, November 7, 2016 2:19:18 PM(UTC)
ThatGuy
Groups: Expert
United States
The shorted solenoid probably fried the control board.
Is your model no. FGHB2844LFE ?
Here is a wiring diagram for that model no.
Parts for Frigidaire FGHB2844LFE / : Wiring Diagram Parts - AppliancePartsPros.com
