Dennis Grunewald
#1 Posted : Tuesday, October 18, 2016 7:30:07 AM(UTC)
Dennis Grunewald
I have a Kenmore side by side refrigerator Model # 253 51392104. The ice maker would not make any ice. All the mechanical parts work like they should. At this time the water filter was leaking. I changed the filter and no more leaks. The ice maker started working and filled the ice storage bin one time and now it is back to not filling the ice tray with water when it should. You can hear the solenoid actuate when it should, but no water and the fill tube is not frozen. I guess I should replace the solenoid water valve. Also, it would not crush the ice when the crushed ice button was depressed. I replaced the solenoid assy # 241675704. It worked for about 10 times and then stopped working again. Replace the solenoid again? That could get expensive. I purchased this solenoid from you. Also, the mechanism that switches from cubed to crushed ice operates freely.
Thanks,
Dennis
ThatGuy
#2 Posted : Tuesday, October 18, 2016 10:42:15 AM(UTC)
ThatGuy
Groups: Expert
United States
I'd bet that the water tube coming into the freezer is frozen up. I used to see that a lot. The ice maker is still turning the water solenoid on and I'll bet if you pulled the tube where in goes into the 45? degree elbow, water would shoot out the next time the IM filled.
If you pull it to clean it look, for hard water deposits. I've seen hard water build up in them before. part 241796405
UserPostedImage
LG LDC24370ST Ice Maker Issues (Refrigerator & Freezer Repair)
by Guest 6/29/2024 8:55:44 AM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
Water Runs Too Long - Ice maker (Refrigerator & Freezer Repair)
by shfdyoung 6/11/2024 3:01:06 PM(UTC)
Bosch Ice Maker Dropping Ice Once Week (Refrigerator & Freezer Repair)
by Guest 5/31/2024 1:40:51 PM(UTC)
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest 3/11/2024 8:34:02 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla 2/16/2024 8:36:50 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Ice maker fiil/dump (Refrigerator & Freezer Repair)
by Guest 2/12/2024 5:46:50 AM(UTC)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 1/3/2024 11:45:50 AM(UTC)
