Eva
#1 Posted : Sunday, February 17, 2008 10:22:04 AM(UTC)
Eva
RCA electric stove model no. L3S340GL0. Oven quit working, flashes F3 code only, push reset button. Unhooked power attempting to reset stove. Replaced oven tempurature sensor, electronic oven control assembly. Still getting F3 code. Any suggestions?
#2 Posted : Monday, February 18, 2008 10:27:26 AM(UTC)
Hi Eva,
Pull the range, remove the rear cover and check the sensor wire harness from the sensor plug to the control board.
Eliminate the sensor plug and hardwire it, using the high temperature porcelain wire nuts (AP3440522).
Check the sensor plug at the control board for tight connection.
GE JGB700SEJ4SS - F3 ERROR CODE (Oven Repair (including Ranges and Cooktops))
by tgdolemite 9/11/2022 6:10:01 AM(UTC)
F3 error code (Oven Repair (including Ranges and Cooktops))
by Mbrondum 9/16/2016 12:05:09 PM(UTC)
E2 F3 error code (Oven Repair (including Ranges and Cooktops))
by garyabone@att.net 12/30/2015 2:52:36 PM(UTC)
F3 error code, even after replacing thermal sensor (Oven Repair (including Ranges and Cooktops))
by wskalyo 1/19/2013 1:33:17 PM(UTC)
F3 error code?? (Oven Repair (including Ranges and Cooktops))
by BOVENGE 12/20/2012 2:33:03 PM(UTC)
Blower won't turn off / F3 error code (Oven Repair (including Ranges and Cooktops))
by Peterpaolo 11/13/2012 4:16:37 PM(UTC)
F3 Error Code (Oven Repair (including Ranges and Cooktops))
by RangerOne 7/26/2012 3:47:51 AM(UTC)
Magic Chef F3 error code even after temp sensor replacement (Oven Repair (including Ranges and Cooktops))
by ponderitsome 7/21/2011 3:46:26 PM(UTC)
front load washer f3 error code (Washer Repair)
by bo_okie1 7/15/2011 6:23:34 AM(UTC)
F1 and F3 error codes (Oven Repair (including Ranges and Cooktops))
by Rhandyman 3/23/2011 10:27:00 AM(UTC)
by Rhandyman 3/23/2011 10:25:34 AM(UTC)
Fisher & Paykel F3 error code :0 (Dishwasher Repair)
by Forkedupdishdrawerguy 11/29/2010 8:32:09 PM(UTC)
F3 error code on Frigidaire oven (Oven Repair (including Ranges and Cooktops))
by k75super 2/8/2010 7:38:15 AM(UTC)
F3 Error Code on GE SpaceMaker XL (Microwave Repair)
by Ckarolak 7/22/2009 12:29:23 PM(UTC)
Frigidaire Oven F3 error code (Oven Repair (including Ranges and Cooktops))
by sbochen 1/7/2008 1:58:12 PM(UTC)
