RangerOne
#1 Posted : Thursday, July 26, 2012 3:47:51 AM(UTC)
RangerOne
This error code is on the top oven only. I know it's the temp sensor, so what I did was to remove the temp sensor from the bottom oven and swap the two. Is this a proper test for testing the sensor? I still get the F3 error code on the top oven. Is my next step changing the control panel?
Simon / APP Team
#2 Posted : Thursday, July 26, 2012 11:33:36 AM(UTC)
Simon / APP Team
Groups: APP Team
HI.
You need to check the resistance of the sensor at the control board.
Unplug the oven, open the control panel and locate plug J3 at the control board.
Disconnect the plug and check the resistance between two white wires. The meter set for 10 kohm.
At the room temperature the resistance should be around 1100 ohm.
Check the wire harness between the sensor and the control board.
Only then if everything check out fine - replace the control
board Part number: WB27T10282
Thank you. Post the results.
Simon.
RangerOne
#3 Posted : Monday, August 20, 2012 1:23:15 PM(UTC)
RangerOne
I ordered a new control panel and installed. Everything works except the top oven won't heat, broiler or bake! I don't get theF3 error code anymore. But the top oven won't work!
#4 Posted : Tuesday, August 21, 2012 12:46:24 PM(UTC)
You said you replaced the control panel?
The control panel is the part with the keypads. The control board is the electronic control behind the control panel which was recommended to replace by Simon.
So, which part did you replace? I'm confused.
Did you check the upper oven temperature sensor?
RangerOne
#5 Posted : Tuesday, August 21, 2012 1:17:32 PM(UTC)
RangerOne
The control board
RangerOne
#6 Posted : Tuesday, August 21, 2012 1:21:40 PM(UTC)
RangerOne
Gene. I replaced the control board. I did check the temp sensor, I even swapped it with the lower oven that works. Anyway could this be the limiter switch?
Simon / APP Team
#7 Posted : Tuesday, August 21, 2012 1:47:12 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please check if the new control board is wired in correctly. The limiter switch according the wiring diagram is only in the lower oven circuitry. Witch doesn't make much of the sense.
See if you can physically find thermal limit switch in the upper oven or reset (if needed) the lower one. It's in the L2 leg.
Thank you.
Simon.
GE JGB700SEJ4SS - F3 ERROR CODE (Oven Repair (including Ranges and Cooktops))
by tgdolemite 9/11/2022 6:10:01 AM(UTC)
F3 error code (Oven Repair (including Ranges and Cooktops))
by Mbrondum 9/16/2016 12:05:09 PM(UTC)
E2 F3 error code (Oven Repair (including Ranges and Cooktops))
by garyabone@att.net 12/30/2015 2:52:36 PM(UTC)
F3 error code, even after replacing thermal sensor (Oven Repair (including Ranges and Cooktops))
by wskalyo 1/19/2013 1:33:17 PM(UTC)
F3 error code?? (Oven Repair (including Ranges and Cooktops))
by BOVENGE 12/20/2012 2:33:03 PM(UTC)
Blower won't turn off / F3 error code (Oven Repair (including Ranges and Cooktops))
by Peterpaolo 11/13/2012 4:16:37 PM(UTC)
Magic Chef F3 error code even after temp sensor replacement (Oven Repair (including Ranges and Cooktops))
by ponderitsome 7/21/2011 3:46:26 PM(UTC)
front load washer f3 error code (Washer Repair)
by bo_okie1 7/15/2011 6:23:34 AM(UTC)
F1 and F3 error codes (Oven Repair (including Ranges and Cooktops))
by Rhandyman 3/23/2011 10:27:00 AM(UTC)
by Rhandyman 3/23/2011 10:25:34 AM(UTC)
Fisher & Paykel F3 error code :0 (Dishwasher Repair)
by Forkedupdishdrawerguy 11/29/2010 8:32:09 PM(UTC)
F3 error code on Frigidaire oven (Oven Repair (including Ranges and Cooktops))
by k75super 2/8/2010 7:38:15 AM(UTC)
F3 Error Code on GE SpaceMaker XL (Microwave Repair)
by Ckarolak 7/22/2009 12:29:23 PM(UTC)
F3 Error Code (Oven Repair (including Ranges and Cooktops))
by Eva 2/17/2008 10:22:04 AM(UTC)
Frigidaire Oven F3 error code (Oven Repair (including Ranges and Cooktops))
by sbochen 1/7/2008 1:58:12 PM(UTC)
