papcap
#1 Posted : Sunday, March 13, 2016 9:37:51 PM(UTC)
papcap
My oven will not hold the temp once it reaches the set temperature. If I set it for 375 it reaches 375. In about 20 minutes I will go back and while the setting still says 375 if I turn the oven off and right back on again for the 375 setting it will be down to around 340 and needs to reheat to bring back to 375. This is without touching the door. Any ideas on what we should check/replace to get it working properly? Thanks
KitchenAid Double Oven Won't Hold Temperature Set at and light won't go off (Oven Repair (including Ranges and Cooktops))
by Guest 5/13/2021 3:39:20 AM(UTC)
Whirlpool oven won't hold temp (Oven Repair (including Ranges and Cooktops))
by Clcmbtn 2/6/2015 3:21:48 PM(UTC)
KitchenAid Oven Won't Hold Temp (Oven Repair (including Ranges and Cooktops))
by bjjansen 1/2/2014 6:19:08 AM(UTC)
oven won't hold temperture (Oven Repair (including Ranges and Cooktops))
by elgeen 11/25/2011 6:31:17 AM(UTC)
by trooper 8/24/2010 12:13:01 PM(UTC)
oven won't hold temperature (Oven Repair (including Ranges and Cooktops))
by pgandrews 4/4/2009 1:08:57 PM(UTC)
Oven won't hold temperature (Oven Repair (including Ranges and Cooktops))
by amasih 3/8/2009 3:54:44 PM(UTC)
