dadunn60
#1 Posted : Tuesday, March 1, 2016 9:43:04 AM(UTC)
dadunn60
Just replaced the Thermal fuse and the dryer worked for a day and blew again. Replaced for a second time and is currently working but is getting extremely hot, as if the heating element is staying on all the time and not cycling off. Checked the heating element and it has 12 ohms of resistance. Could this be the inlet thermistor? Any help would be greatly appreciated!!
dadunn60
#2 Posted : Thursday, March 3, 2016 4:47:27 PM(UTC)
dadunn60
anyone with any suggestions? Starting to think maybe the control board?
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
Kenmore gas dryer overheating and shutting down in permanent press setting (Dryer Repair)
by Actonite 8/14/2022 4:57:32 PM(UTC)
Whirlpool dryer overheating, replaced thermostats (Dryer Repair)
by rastoma 10/18/2017 6:29:27 PM(UTC)
Kenmore Dryer Overheating and weak (Dryer Repair)
by Cardiaccat 9/3/2017 9:25:50 AM(UTC)
Dryer Overheating When Not Running (Dryer Repair)
by Chris McCain 4/5/2017 8:06:45 AM(UTC)
Maytag Dryer Overheating (Dryer Repair)
by atem2144 10/28/2016 12:34:41 PM(UTC)
dryer overheating (Dryer Repair)
by dave3712 10/15/2016 8:16:37 AM(UTC)
Estate Dryer Overheating. I suspect hot air leaking from drum (Dryer Repair)
by Picklefall1 9/12/2016 8:13:23 PM(UTC)
Kenmore Dryer Overheating (Dryer Repair)
by atem2144 8/17/2016 1:41:31 PM(UTC)
Belarus sfhutchi 2/28/2015 1:57:08 PM(UTC)
Whirlpool Dryer Overheating (Dryer Repair)
by TravisC 1/17/2015 11:13:36 AM(UTC)
by HawtDog 1/12/2015 1:59:21 PM(UTC)
Duet Dryer Overheating (Dryer Repair)
by Snarlybarley 11/20/2013 6:44:40 AM(UTC)
Dryer Overheating When Turned Off (Dryer Repair)
by Jeffshumaker 10/13/2013 4:27:05 PM(UTC)
Dryer overheating (Dryer Repair)
by jltuttl 8/30/2013 10:09:52 AM(UTC)
