Davedoxie
#1 Posted : Monday, February 15, 2016 5:03:19 AM(UTC)
Davedoxie
My Samsung upright Washer is shaking so bad on its spin cycle and shuts off around number 6 when the washer is counting down. Clothes are still wet. Almost sounds like it's going to go down through the floor. The washer is level floor is strong. Reading other Threads could this be a broken spider? Would it still work with a broken spider. Thanks
Samsung Washer No Agitation or Spin (Washer Repair)
by amappliancewi 2/7/2024 10:24:03 AM(UTC)
Samsung washer balancing (Washer Repair)
by AF96 3/18/2023 8:50:39 AM(UTC)
SAMSUNG WASHER CODE 9e1 (Washer Repair)
by Vsparaney 12/14/2022 9:41:28 PM(UTC)
Samsung Washer WA50F9A8DSP/A2-01 (Washer Repair)
by Vsparaney 12/13/2022 10:05:08 PM(UTC)
Samsung Washer not going into fast spin (Washer Repair)
by Guest 9/13/2022 10:10:14 AM(UTC)
Samsung Washer Spin Racket - Not the Bearing or Shock! (Washer Repair)
by lothian.mcadam 8/14/2022 7:15:24 PM(UTC)
Samsung washer won't spin (Washer Repair)
by Guest 1/8/2022 10:56:39 AM(UTC)
Samsung washer not working (Washer Repair)
by ermannojdangelo@gmail.com 9/11/2021 10:36:05 AM(UTC)
samsung washer drains detergent (Washer Repair)
by Guest 7/30/2021 10:38:39 AM(UTC)
Samsung Washer WF42H5400AF/A2 (General Talk)
by Chops 1/16/2021 8:51:39 AM(UTC)
Samsung washer wf50k7500av/a2 (Washer Repair)
by Kian010 9/29/2020 8:57:15 PM(UTC)
Samsung washer fills even after turn off (Washer Repair)
by bpaulik 6/4/2020 4:42:14 AM(UTC)
Samsung washer shock bearing (Washer Repair)
by Jaslikow 5/30/2020 3:43:53 PM(UTC)
Samsung Washer no Power (Washer Repair)
by SalmanUSA 4/21/2020 8:50:15 PM(UTC)
Samsung Washer Making Noise (Washer Repair)
by Bob_Bob356 4/21/2020 10:13:29 AM(UTC)
