Joined: 5/25/2020(UTC) Posts: 0  Location: California
Hi, I have a Samsung WF210ANW front loading washer. I purchased new shocks for the front and removed on the old ones. The numbers on the side of the shocks are the same but the new one has a bearing in keyhole on the tub side of the shock that is too small for the pin on the bottom of the tub. The old shock is identical but does not have the bearing. Is it normal to remove that bearing for certain washer types? The shock part number is DC66-00470A. Thank you, Adam Edited by user Saturday, May 30, 2020 3:48:01 PM(UTC)
| Reason: Not specified
