I have a Whirlpool WFG374LVS2 gas range that has an ignition problem in the oven. I have gas at the oven but intermittent spark. This happens intermittently. It clicks three times (probably hearing the broiler) but I have watched the igniter, which is new, and there is NO spark. I just checked the gas valve solenoids and they both show 193 ohms. The broiler works just fine. Could this be the Spark module? Thanks.
Hello Tag1260, This can be caused by losing a good ground to the burner or a failing spark module Part number: AP5178660
