I have a Whirlpool WFG374LVS2 gas range that has an ignition problem in the oven. I have gas at the oven but intermittent spark. This happens intermittently. It clicks three times (probably hearing the broiler) but I have watched the igniter, which is new, and there is NO spark. I just checked the gas valve solenoids and they both show 193 ohms. The broiler works just fine. Could this be the Spark module? Thanks.
Groups: Guests
Hello Tag1260, This can be caused by losing a good ground to the burner or a failing spark module Part number: AP5178660
