tag1260
#1 Posted : Wednesday, January 27, 2016 6:36:02 AM(UTC)
tag1260
I have a Whirlpool WFG374LVS2 gas range that has an ignition problem in the oven. I have gas at the oven but intermittent spark. This happens intermittently. It clicks three times (probably hearing the broiler) but I have watched the igniter, which is new, and there is NO spark. I just checked the gas valve solenoids and they both show 193 ohms. The broiler works just fine. Could this be the Spark module? Thanks.
Jerry / APP Team
#2 Posted : Friday, January 29, 2016 11:42:36 AM(UTC)
mattt
Groups: Guests
Hello Tag1260,
This can be caused by losing a good ground to the burner or a failing spark module Part number: AP5178660
