chito macario
Please start you own thread using POST NEW TOPIC hijacking/ piggy backing on a thread when your model is different will just confuse things. Also include your model number.
Thanks in advance
gbrogan Here are your parts
Replacement parts for AMANA LE4407W | AppliancePartsPros.comFirst try flipping your breaker off/on a couple times slowly. Sometimes you can loose half the line without actually tripping the breaker. Better yet measure it with a meter L1 to L2 should be 240 volts which is required by the heater.
Next check the heater itself, should be around 10 ohms. Sometimes you can see the break.
Next would be:
Thermal fuse Item 4 Section 6
Operating Thermostat Item 24 Section 10
Hi-limit thermostat Item 6 Section 6
All should be 0 ohms at room temperature.
