gjack45pac
#1 Posted : Saturday, November 28, 2015 9:40:28 AM(UTC)
gjack45pac
Power good to dryer
Door switch working
start button working
across two hot legs on timer only 88 volts
dryer will not run please help!
#2 Posted : Sunday, November 29, 2015 2:02:10 AM(UTC)
Check your power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the wall receptacle
L1 to L2 should be 240 volts
If OK
If OK
dryer wont run (Dryer Repair)
by patriots 4/26/2015 10:21:36 AM(UTC)
Maytag Dryer wont run, burnt red wire from timer to temp control (Dryer Repair)
by Hurricane 9/4/2014 10:41:37 AM(UTC)
Kenmore HE4 Front load Dryer wont Run (Dryer Repair)
by hunterhutch 12/23/2013 6:19:04 AM(UTC)
dryer wont run control panel lights up (Dryer Repair)
by bobbijo 8/11/2013 2:13:57 PM(UTC)
Dryer wont run (Dryer Repair)
by wtester 12/3/2012 3:20:38 AM(UTC)
by jlp10 5/31/2011 4:34:08 PM(UTC)
by indybassin 2/21/2011 1:17:15 PM(UTC)
Maytag electric dryer wont run (Dryer Repair)
by crotonoil 12/9/2010 1:40:55 PM(UTC)
by latj 5/26/2010 5:11:49 AM(UTC)
by jgiff@att.net 1/25/2010 6:33:35 AM(UTC)
Maytag dryer wont run (Dryer Repair)
Belarus Dennisb 1/5/2010 2:14:39 PM(UTC)
dryer wont run after making squeaky noise (Dryer Repair)
by pattie 9/18/2009 10:59:40 PM(UTC)
by nairobi 9/16/2009 2:02:01 PM(UTC)
dryer wont run at all (Dryer Repair)
by neighbor 9/16/2009 7:04:39 AM(UTC)
by danielle 10/22/2008 5:55:37 PM(UTC)
