Strum310
#1 Posted : Sunday, November 15, 2015 5:57:23 PM(UTC)
Strum310
Jennair dishwasher jdb1250awp. Some of the touch panel buttons weren't working for a while but it still worked. Now nothing lights up and the dishwasher will not turn on. Is it the touch panel and control?
Thanks for help!!
#2 Posted : Monday, November 16, 2015 1:38:32 AM(UTC)
Parts for Jenn-Air JDB1250AWP Dishwasher - AppliancePartsPros.com
Could be either part.
The usual way to troubleshoot this is to check the key/pinouts of the control panel with a meter.
Then if it checks out OK replace the control board.
Still a bit of a crap shoot but your odds are better.
You may want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
my dishwasher won't start a cycle (Dishwasher Repair)
by Guest 1/13/2023 9:06:08 PM(UTC)
Frigidaire dishwasher won't start, all lights are blinking (Dishwasher Repair)
by Guest 11/22/2021 4:33:30 PM(UTC)
Frigidaire Dishwasher Won't Start (FFBD2406NS9B) (Dishwasher Repair)
by Radamis 8/3/2020 8:14:55 AM(UTC)
Viking DDB325SS Dishwasher won't start (Dishwasher Repair)
by tmman 6/10/2020 6:44:15 AM(UTC)
Bosch dishwasher won't start after power surge (Dishwasher Repair)
by Larry120 7/17/2018 11:07:27 AM(UTC)
Bosch dishwasher won't start -- display flashes time (Dishwasher Repair)
by rsilk 6/28/2018 6:21:47 PM(UTC)
Dishwasher won't start when house is too cold (Dishwasher Repair)
by manshack_one 1/2/2018 8:13:29 AM(UTC)
dishwasher won't start (Dishwasher Repair)
by goosemasterkl 9/6/2017 5:03:10 PM(UTC)
Ge dishwasher won't start (Dishwasher Repair)
by gegerva 10/9/2016 5:45:31 AM(UTC)
GE dishwasher won't start (Dishwasher Repair)
by tyanbinh 6/10/2016 7:01:58 PM(UTC)
Dishwasher won't start cycle (Dishwasher Repair)
by fugue 4/16/2016 4:33:36 AM(UTC)
Maytag dishwasher won't start unless I manually hold door closed (Dishwasher Repair)
by RepairKing53 1/29/2016 10:14:13 AM(UTC)
by Tricjabs 1/26/2016 5:41:06 PM(UTC)
by dhbrittain 9/9/2015 3:35:11 PM(UTC)
dishwasher won't start - control board or console? (Dishwasher Repair)
by jk_LB2008 10/29/2014 5:19:57 PM(UTC)
