My dishwasher started and filled with water, then quit. Even though I move dial, it will still not do anything. There is power to the unit. What do I do?
Here are your parts Parts for Whirlpool DU8770XY1 Dishwasher - AppliancePartsPros.comSee the attachment for the tech sheet. Sounds like it could be a timer problem which is no longer available. I would check for bad connections/wires in the unit. You could also try different options to see if anything will work after a fill. This is an old unit so unless you can find the bad part on your own, I would not get a service man it to trouble shoot it. That would cost $100.00 or more so it probably makes more sense to put the dollars towards a new unit. |
THIS FORUM IS DEAD!!!!!!! |
