I have a KitchenAid KSSP48QHW00 and the Bullet Valve is iced over on the suction line. I'm not an expert, but I hooked up gages and it seems the low-side is at 20PSI (with refrigerator on). The following have already been replaced: 1. Defrost Timer 2. Evaporator Fan 3. Compressor Relay 4. Refrigerator Thermostat Here are pictures: http://postimg.org/image/xhgvniqur/ http://postimg.org/image/8uwevkjfr/Any help would be greatly appreciated. .
Is that ball of ice on the tubing leading into the evaporator coils? If so, a ball of hard ice at the beginning of the evaporator coil indicates low refrigerant or obstruction in the sealed system.
