drum is making a thump noise towards the back and bottom of drum,what are possible problems
I cannot find info/parts for this unit but thumping is usually cause by the drum support rollers.
One or them is probably out of round.
Also check that the drum itself has not split on the seam. |
THIS FORUM IS DEAD!!!!!!! |
