lg07dec
#1 Posted : Monday, September 14, 2015 3:59:45 PM(UTC)
lg07dec
drum is making a thump noise towards the back and bottom of drum,what are possible problems
#2 Posted : Tuesday, September 15, 2015 2:28:58 AM(UTC)
I cannot find info/parts for this unit but thumping is usually cause by the drum support rollers.
One or them is probably out of round.
Also check that the drum itself has not split on the seam.
DLEX5780WE lg dryer shutting off before the clothes are dry. (Dryer Repair)
by LMA 4/13/2024 11:00:21 AM(UTC)
LG Dryer High Heat (Dryer Repair)
by jlanz@peak.org 1/21/2024 8:57:58 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
LG Dryer DLGY1702VE no error codes (Dryer Repair)
by Lisssasue 7/17/2023 10:41:37 AM(UTC)
LG Dryer Model DLE2301R (Dryer Repair)
by JimBAgde 6/23/2023 3:18:55 PM(UTC)
LG dryer heat stops during load (Dryer Repair)
by Guest 4/15/2023 10:14:22 AM(UTC)
LG Dryer wont turn off - DLGX8101V (Dryer Repair)
by cameroninoc 2/3/2023 1:22:44 PM(UTC)
LG dryer filter (Dryer Repair)
by bayebaa 12/4/2022 7:18:10 PM(UTC)
LG Dryer filter recognition (Dryer Repair)
by Guest 12/4/2022 7:11:09 PM(UTC)
LG Dryer Heater Thermistor Error (Dryer Repair)
by Guest 11/16/2022 8:37:57 AM(UTC)
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
LG dryer dlex 3360v (Dryer Repair)
by Guest 10/29/2021 8:46:19 AM(UTC)
LG Dryer wont turn on (Dryer Repair)
by stz2 7/28/2021 2:09:54 AM(UTC)
Smell gas while running - LG Dryer (Dryer Repair)
by bucklahoo 12/10/2020 8:35:34 AM(UTC)
LG Dryer seal too much friction (Dryer Repair)
by MPowell1066 11/15/2020 5:12:37 AM(UTC)
