Hryarhucb
#1 Posted : Sunday, September 6, 2015 5:25:26 PM(UTC)
Hryarhucb
I have the above named & model # Refrigerator. Two door no frost 19 cu. ft. The refrigerator runs all the time. The top freezer compartment gets down to 12 degrees F and at the same time the lower fresh food compartment sometimes gets down to 32 degrees F. Then about two to three hours later the top freezer compartment goes up to 45 degrees F and at the same time the lower fresh food compartment goes up to 65 degrees F,
this process repeats itself over and over.
Does anyone have a clue as to what might be causing this to happen, and what the remedy might be?
Thanks,
Hryarhucb
jon.wilob
#2 Posted : Sunday, September 6, 2015 7:31:13 PM(UTC)
jon.wilob
That problem on my fridge was solved by replacing the sticking damper in the cold food section.
Hryarhucb
#3 Posted : Monday, September 7, 2015 12:48:39 PM(UTC)
Hryarhucb
Thanks, jon.wilob. I checked the damper it is ok and plenty of air is coming down to the fresh food compartment. However the ref. runs all the time and about every two- three hours it goes from 20 deg, in the freezer compartment to 60 degrees and same temp, of 60 degrees in fresh food comp. It repeats this cycle over & over.
Hryarhucb
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6/16/2024 8:15:11 AM(UTC)
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6/15/2024 8:12:03 AM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 5/28/2024 7:48:32 PM(UTC)
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 5/28/2024 3:17:33 PM(UTC)
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 5/23/2024 11:20:53 AM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Refrigerator Ice (Refrigerator & Freezer Repair)
by Guest 5/9/2024 7:00:37 AM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
