hoffmasedingeaux
#1 Posted : Friday, August 7, 2015 3:29:38 PM(UTC)
hoffmasedingeaux
Recently bought a house with this refrigerator in it. The freezer and refrigerator works fine. I cannot get the ice maker to work. The unit will dispense water but no ice. The dispenser turns in an effort to drop ice but there is no ice to give.
This fridge has a touchscreen display and a removable ice bin.
It is acting like it thinks it is full of ice and does not need to make any more. I pressed the ice maker test switch and the slinger rotated around.
I don't know what to check (optical eyes)?
Thanks for any help
CletusT
#2 Posted : Sunday, August 9, 2015 7:51:47 PM(UTC)
CletusT
It's a fairly standard ice maker. The fill valve has to actuate to fill the ice molds before it can make ice.
It has to be around 20 degrees, give or take, in order for the ice maker mechanism to work correctly.
I would check the filter as well. Listen to see if the valve actuates to fill the ice maker mold. You should hear it open.
I would check the spout leading into the ice maker to see if it has been blocked by ice freezing before it can reach the molds too.
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 9/27/2022 12:38:23 PM(UTC)
Sub-zero ice maker not working - water line? (Refrigerator & Freezer Repair)
by doingthebestican 4/28/2021 11:44:07 AM(UTC)
Samsung RF267 fridge ice maker not working (Refrigerator & Freezer Repair)
by splumer 4/8/2021 11:13:45 AM(UTC)
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 12/11/2020 4:23:17 PM(UTC)
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 11/14/2020 10:28:34 AM(UTC)
GE Mother Board Replacement - Ice Maker Not Working (Refrigerator & Freezer Repair)
by oneijack 4/20/2020 7:26:54 PM(UTC)
Maytag WRX735SDHZ00 Ice Maker not working (Refrigerator & Freezer Repair)
by mp1975 11/9/2019 3:32:25 PM(UTC)
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 10/19/2019 2:18:49 PM(UTC)
GE Artica ice maker not working (Refrigerator & Freezer Repair)
by gr8filed 9/28/2019 4:41:03 AM(UTC)
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 6/26/2018 11:54:43 AM(UTC)
Ice maker not working (Refrigerator & Freezer Repair)
by Stuckbad 9/17/2017 11:20:17 AM(UTC)
Ice Maker not working after replacing several parts (Refrigerator & Freezer Repair)
by Rylos 9/9/2017 12:46:10 PM(UTC)
frigidaire ffss2614qs0 ice maker not working but dispenses water (Refrigerator & Freezer Repair)
by whstrain 7/29/2017 8:42:47 AM(UTC)
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 7/21/2017 9:34:37 AM(UTC)
