rjcarrell
#1 Posted : 10 years ago
rjcarrell
Center divider strip between doors is extremely hot. Unit cooling fine on both sides but runs almost continually. Cleaned coils per directions in manual best I could, no help.
#2 Posted : 10 years ago
Did you check that the condenser/compressor fan was running.
And that it is blowing correctly.
I would also check the fan blades as dirty blades can drastically reduce air flow.
Also check that the rear cover vents and the kick plate vents are clean.
David West
#3 Posted : 10 years ago
David West
read this: How to Fix a Whirlpool & KitchenAid W10219463 / 2307028 Control Board for $6 - SteveJenkins.com
If you're handy with a screwdriver & soldering iron, you can fix it yourself -- I did.
Kitchenaid Fridge Longer Cold (Refrigerator & Freezer Repair)
by FridgeHelpPlease about a year ago
KitchenAid fridge KSCS25FTMS02 ice maker stops (Refrigerator & Freezer Repair)
by dj_k2000 2 years ago
KitchenAid Fridge ( Model kbsd602ess01) won't dispense crushed ice (Refrigerator & Freezer Repair)
by Manuel Ribeiro 2 years ago
KitchenAid Fridge has frost in the freezer (Refrigerator & Freezer Repair)
by Guest 2 years ago
Kitchenaid fridge too cold. Freezer OK. (Refrigerator & Freezer Repair)
by Dgclarkson 4 years ago
Kitchenaid Fridge Lights off Not dispensing Ice/Water (Refrigerator & Freezer Repair)
by George1234 5 years ago
Kitchenaid Fridge KSCS25INSS00 (Refrigerator & Freezer Repair)
by mickkassem 6 years ago
Kitchenaid Fridge Lights, Ice, and Water not working (Refrigerator & Freezer Repair)
by Biglurr54 8 years ago
Kitchenaid Fridge with lots of problems (Refrigerator & Freezer Repair)
by zumpa21 9 years ago
KSCS25FTMS - Kitchenaid Fridge Lights/IceMaker Not Working - But Fridge/Freezer Work (Refrigerator & Freezer Repair)
by cgsauer 10 years ago
Kitchenaid Fridge - Controls not workin (Refrigerator & Freezer Repair)
by hebertpl 11 years ago
Kitchenaid Fridge Trips GFI (Refrigerator & Freezer Repair)
by ahursh 12 years ago
Kitchenaid Fridge Freezer fault (Refrigerator & Freezer Repair)
by davesmckee 12 years ago
Kitchenaid Fridge Light Not Working (Refrigerator & Freezer Repair)
by RowRow 13 years ago
Kitchenaid Fridge Icemaker not working (Refrigerator & Freezer Repair)
by lancecowell 13 years ago
