shadowfree65
#1 Posted : Wednesday, July 8, 2015 8:55:01 AM(UTC)
shadowfree65
This dryer has no heat. it runs but not heat. I have replaced heating unit and thermal fuse. Have no idea what else it can be. please help!
#2 Posted : Wednesday, July 8, 2015 9:32:20 AM(UTC)
A model number may be helpful
Find your model number - AppliancePartsPros.com
Also did you replace the thermal fuse or the thermal cutoff.
The fuse kills power to the unit/motor.
The cutoff kills power to the heating coil.
Have you checked the power?
I would do that before going any further.
The heating element requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Amana electric dryer not working (Dryer Repair)
by Guest 5/3/2024 10:43:01 AM(UTC)
Kenmore Electric Dryer 110.65132411 (Dryer Repair)
by Guest 5/1/2024 5:58:30 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Kenmore electric dryer typical model 110.68522700 (Dryer Repair)
by Guest 2/22/2024 10:10:02 AM(UTC)
Maytag Electric dryer model MEDC300XW0 (Dryer Repair)
by Guest 2/6/2024 1:56:33 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Speed Queen electric dryer model ADE3LRG8171TWoi (Dryer Repair)
by Guest 11/26/2023 2:53:33 AM(UTC)
Kenmore electric dryer model 110.68622700 (Dryer Repair)
by Guest 11/12/2023 6:47:37 PM(UTC)
