howard6168
#1 Posted : Sunday, July 5, 2015 5:47:41 AM(UTC)
howard6168
My over and under washer/dryer combo started screeching, and stopped in the spin mode. Electrical smells emanated, and the washer would not spin.
I unloaded the clothes, and tried just the spin mode, but again nothing but the screech and smell. I assume the motor has seized, but would appreciate any other areas to look at.
thanks,
sidfink43
#2 Posted : Monday, July 6, 2015 12:47:52 PM(UTC)
sidfink43
Take off the front panel and check the belts and the pump. You may have something stuck in the pump, turn the belt that is connected to the pump to tell. If the motor will not turn it is likely the motor. If the belt to the transmission will not turn it may be the transmission.
Whirpool washer will not spin (Washer Repair)
by Guest 1/27/2022 11:02:31 AM(UTC)
Washer Will Not Spin Out Water. (Washer Repair)
by Guest 6/5/2021 1:32:58 PM(UTC)
GE Profile Harmony washer will not spin - grinding (WPGT9150HWW) (Washer Repair)
by jmac2287 12/3/2019 11:25:46 AM(UTC)
Washer will not spin (Washer Repair)
by lftfield09 6/9/2017 4:58:09 PM(UTC)
Stacked Washer dryer- washer will not spin and empty (Washer Repair)
by anderson3818 6/8/2017 7:57:48 AM(UTC)
washer will not spin out.. (Washer Repair)
by coastie1160870 1/11/2017 10:41:54 PM(UTC)
GE washer will not spin (Washer Repair)
by MS104 5/10/2016 4:34:48 PM(UTC)
Maytag Atlantis Washer will not spin (Washer Repair)
by lvavis 8/26/2015 7:56:10 PM(UTC)
Kenmore 800 Washer will not spin (Washer Repair)
by AnneKenzie 6/18/2015 12:01:29 PM(UTC)
Frigidaire Washer will not spin (Washer Repair)
by luvmylars 4/30/2015 11:33:25 AM(UTC)
washer will not spin out (Washer Repair)
by kdwarren16yrs 12/27/2014 6:42:50 AM(UTC)
ge profile washer will not spin (Washer Repair)
by ron dog 11/29/2014 5:27:31 PM(UTC)
Washer will not spin/drain (work) (Washer Repair)
by dupdc 8/20/2014 2:50:08 AM(UTC)
Whirlpool Cabrio Washer Will Not Spin (Washer Repair)
by pacdave 5/7/2014 6:40:52 PM(UTC)
by proturf 4/1/2014 2:12:21 PM(UTC)
