My kenmore dishwasher is not draining completely after it finishes a cycle. If i select cancel/drain it will drain the water just fine. I already cleaned out the filters and checked for debris. i also cleaned out the hose line but the problem is still there. please help.
Regards,
Sanjay
Groups: APP Team
Hi. You need to make sure the pump filter, the drain hose and the air-gap are all clean. Disconnect the drain hose from the air-gap, put the hose in a tall bucket, start the dishwasher in the drain cycle and check the strength of the water flow. If water is not shooting from the hose you may need a new drain pump. If it does, then check the air-gap. The drain pump Part number: W10348269
Good luck. Please, keep us posted of the results. Thank you, Simon.
