sanjayg1971
#1 Posted : Wednesday, July 1, 2015 10:37:25 AM(UTC)
sanjayg1971
My kenmore dishwasher is not draining completely after it finishes a cycle. If i select cancel/drain it will drain the water just fine. I already cleaned out the filters and checked for debris. i also cleaned out the hose line but the problem is still there. please help.
Regards,
Sanjay
Simon / APP Team
#2 Posted : Wednesday, July 1, 2015 3:04:38 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to make sure the pump filter, the drain hose and the air-gap are all clean. Disconnect the drain hose from the air-gap, put the hose in a tall bucket, start the dishwasher in the drain cycle and check the strength of the water flow. If water is not shooting from the hose you may need a new drain pump. If it does, then check the air-gap.
The drain pump Part number: W10348269
Good luck. Please, keep us posted of the results.
Thank you,
Simon.
bosch dishwasher not draining after cycle (more than usual) (Dishwasher Repair)
by mpmurphy 11/3/2009 5:16:32 PM(UTC)
Dishwasher not draining after cycle ends (Dishwasher Repair)
by Roy B 3/1/2009 6:05:52 AM(UTC)
Dishwasher not draining after cycle (Dishwasher Repair)
by rritter 11/28/2007 6:28:06 PM(UTC)
