gman2233
#1 Posted : Wednesday, May 27, 2015 6:32:08 PM(UTC)
gman2233
During a wash cycle the machine stopped. The lights were still on and it wouldn't drain. I couldn't power the machine off or open the door. I unplugged it and plugged it back in. I couldn't run the drain/spin cycle. I drained the water manually and opened the door with the manual over ride to get the clothes out. The washer turns on and the door locks but the cycle never begins. I ran the diagnosis test and it will fill and drain but when it drains it gets stuck and keeps draining even when there is nothing to drain. Also I don't get any errors on the diagnosis test.
sidfink43
#2 Posted : Friday, May 29, 2015 6:57:52 AM(UTC)
sidfink43
If the diagnostics fails that is usually a sign that the main control unit has failed. Use the tech notes to see if you can do some component testing, along with testing the motor control board. If you cannot determine anything try replacing the main control unit. If you buy from this site and that part does not fix things you can return it. See the returns policy.
gman2233
#3 Posted : Friday, May 29, 2015 7:06:52 AM(UTC)
gman2233
Before posting this article, I thought it was the MMC and swapped it. The problem still happens with the new one.
I have a video of the problem http://youtu.be/X60zAAxEcO4
whirlpool washing machine model wtw57esvw0 (Washer Repair)
by Guest 5/7/2024 7:57:17 AM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
Whirlpool washing machine drive hub (Washer Repair)
by Guest 4/23/2023 7:29:26 AM(UTC)
Whirlpool washing machine not spinning properly (Washer Repair)
by Guest 6/9/2021 9:12:59 PM(UTC)
Whirlpool washing machine destroying water pumps (Washer Repair)
by mjcarb 8/30/2016 11:53:49 AM(UTC)
Whirlpool washing machine drain/spin noise (Washer Repair)
by wlakeberry84 6/24/2014 8:25:04 PM(UTC)
whirlpool washing machine (Washer Repair)
by tungkiu 12/5/2013 3:42:15 PM(UTC)
Whirlpool Washing Machine Plastic Washers (Washer Repair)
by ohcableman 7/4/2013 10:28:31 AM(UTC)
whirlpool washing machine will not spin out everytime (Washer Repair)
by rdgiles1 4/16/2013 6:50:00 AM(UTC)
Whirlpool Washing Machine (Washer Repair)
by Texasdiyer 3/25/2013 5:10:12 AM(UTC)
Whirlpool Washing Machine Agitates for the entire cycle (Washer Repair)
by swkucera 12/4/2012 5:09:02 AM(UTC)
by edie590 8/16/2012 8:29:21 AM(UTC)
by allantag 8/2/2012 12:58:01 PM(UTC)
by sunshine123 9/3/2011 8:05:34 PM(UTC)
Whirlpool washing machine LSQ9010KQ0 timer replace instrucions (Washer Repair)
by PlankOwner 12/29/2010 8:59:42 PM(UTC)
