CATAXMAN
#1 Posted : Friday, May 22, 2015 7:42:29 AM(UTC)
CATAXMAN
Plumber says the lines are not the problem. Garbage disposal works properly. The water in the dishwasher will not drain. My best guess is it is an internal pump problem. Can anyone tell me how to confirm this and then fix it, or do I need to get a repair person out?
#2 Posted : Saturday, May 23, 2015 3:11:27 AM(UTC)
Views messages in topic : 19,638
Did this unit ever drain at this location?
Has anything changed with the plumbing hook up re: new garbage disposal etc.?
GE washer drain problem (Washer Repair)
by gurka75 11/16/2023 10:07:53 AM(UTC)
lg wm2277hs drain problem (Washer Repair)
by Spiderman70 7/30/2020 6:37:35 AM(UTC)
kitchen aid drain problem not all the time (Dishwasher Repair)
by tom setre 1/22/2019 8:34:59 AM(UTC)
Neptune MAH7500 - drain problem (Washer Repair)
by matopruth 3/8/2014 8:35:04 AM(UTC)
Maytag Neptune MAH5500BWW drain problems (Washer Repair)
by Tyork1 11/29/2013 6:02:24 PM(UTC)
neutral drain problem (Washer Repair)
by Tim2020 8/16/2013 9:47:57 PM(UTC)
Washing machine drain problem (Washer Repair)
by jon_e 1/5/2013 11:30:20 AM(UTC)
by hollowayv 12/4/2012 8:09:39 AM(UTC)
Fridigaire front loader drain problems (Washer Repair)
by jesse.rizzo 11/11/2012 10:52:28 AM(UTC)
Maytag Neptune Drain Problem (Washer Repair)
by dhornman 8/22/2012 9:04:48 AM(UTC)
Dishwasher drain problem (Dishwasher Repair)
by hunterman 11/14/2011 7:56:54 AM(UTC)
by youngstown2 11/12/2011 7:11:48 AM(UTC)
spin and drain problem calypso (Washer Repair)
by jim806 6/27/2011 2:25:50 PM(UTC)
Intermittent fill/drain problem (Dishwasher Repair)
by nele 4/22/2011 5:59:37 AM(UTC)
by Tom Wardynski 3/7/2011 3:25:54 PM(UTC)
