I have an LG wm2277hs and now my clothes don't drain. The machine works perfectly until it time to go into the final spin and then I get a "UE" error. There is no blockage in the hoses. If I open the door and continue the cycle it does the same thing in another 5 minutes or so. Please help. See link below http://techisles.com/wp-...07/20200713_013351-1.mp4
Check your coin drain and filter. I had the same issue. Pulled it out (mine It’s on the bottom left in the front) cleaned it out by removing a few coins and quite a bit of thread. After that it worked perfectly
