Spiderman70
#1 Posted : Thursday, July 30, 2020 6:37:35 AM(UTC)
Spiderman70
Bahamas
I have an LG wm2277hs and now my clothes don't drain. The machine works perfectly until it time to go into the final spin and then I get a "UE" error.
There is no blockage in the hoses. If I open the door and continue the cycle it does the same thing in another 5 minutes or so. Please help.
See link below
http://techisles.com/wp-...07/20200713_013351-1.mp4
Maliksmom2000
#2 Posted : Tuesday, September 8, 2020 10:33:49 AM(UTC)
Maliksmom2000
Check your coin drain and filter. I had the same issue. Pulled it out (mine It’s on the bottom left in the front) cleaned it out by removing a few coins and quite a bit of thread. After that it worked perfectly
