AppliancePartsPros.com
Appliance Repair Help
Washer Repair
BAFFLED!! LG Washer won't drain. Drain clear, pump works.
Rank:: Member
Washer won't drain... just spins slowly and eventually lands at OE Error code.
Model WT5101HV. I've checked all the lines, pulled the pump and put to 120V on the bench. works fine.
Reinstalled pump and bypassed the power to the pump on the machine, hooking directly to 120V during the drain cycle, and it shot water out, performing exactly as it should.
It seems something simply isn't telling the pump to engage.
Is there a drain relay that tells the pump when to switch on? Control board issue?
Thanks for following up and letting us know the solution. Sorry I didn't get to you fast enough
Washer Repair
