SimplyBaffled
#1 Posted : 10 years ago
SimplyBaffled
Washer won't drain... just spins slowly and eventually lands at OE Error code.
Model WT5101HV. I've checked all the lines, pulled the pump and put to 120V on the bench. works fine.
Reinstalled pump and bypassed the power to the pump on the machine, hooking directly to 120V during the drain cycle, and it shot water out, performing exactly as it should.
It seems something simply isn't telling the pump to engage.
Is there a drain relay that tells the pump when to switch on? Control board issue?
bugmenot11
#2 Posted : 9 years ago
bugmenot11
It was asked in this other forum and it was solved:
FIXED STUMPED! LG Washer won't drain. Pump works. No debris in lines.
Appliance Medics
#3 Posted : 9 years ago
Appliance Medics
Thanks for following up and letting us know the solution. Sorry I didn't get to you fast enough
