spkt2015
#1 Posted : Monday, May 18, 2015 8:39:28 AM(UTC)
spkt2015
My Kenmore 90 series washer has following symptoms:
1. Fills water correctly.
2. Does not agitate or spin. I hear the motor working.
3. Drains water correctly at the end of a cycle. I used the pre-wash
cycle to check this.
Please help me diagnose what is the issue and how could I fix it. Any more tests I need to run to narrow down the cause ?
Thanks in advance for your help.
SPKT
fairbank56
#2 Posted : Monday, May 18, 2015 11:07:48 AM(UTC)
fairbank56
Groups: Expert
Sounds like a faulty motor coupler. See video on this link.
Whirlpool 285753A Whirlpool Direct Drive Washer Motor Coupling - AppliancePartsPros.com
Eric
spkt2015
#3 Posted : Tuesday, May 19, 2015 3:43:00 AM(UTC)
spkt2015
Thanks so much !!! Opened it using the video instructions. Just like you said, the coupler was broken. Ordered it here. Should be coming in a few days.
spkt2015
#4 Posted : Sunday, May 24, 2015 12:36:38 PM(UTC)
spkt2015
Installed the new coupler. The machine is working again. Doing multiple pending loads today. Thanks !!!
