My Kenmore 90 series washer has following symptoms:
1. Fills water correctly. 2. Does not agitate or spin. I hear the motor working. 3. Drains water correctly at the end of a cycle. I used the pre-wash cycle to check this.
Please help me diagnose what is the issue and how could I fix it. Any more tests I need to run to narrow down the cause ?
Thanks in advance for your help.
SPKT
Groups: Expert
Thanks so much !!! Opened it using the video instructions. Just like you said, the coupler was broken. Ordered it here. Should be coming in a few days.
Installed the new coupler. The machine is working again. Doing multiple pending loads today. Thanks !!!
