stringbender
#1 Posted : 10 years ago
stringbender
I have performed continuity tests on 5 parts and ALL passed. I removed them first to do the tests. High Limit Thermostat
Cycling Thermostat
2 Thermal Fuses
Heating Assembly.
The timer does not work like it is supposed to. Sometimes it won't shut off. This is a perplexing issue. It requires multiple cycles to dry clothes yet it doesn't appear to heat up correctly. From what I have read online the timer usually doesn't cause heating issues. Any ideas? :confused:
fairbank56
#2 Posted : 10 years ago
fairbank56
Groups: Expert
The timer is in fact, most likely the problem. The timer does control the heat circuit and the type of timer used on this model is a piece of junk and a very high failure item.
Whirlpool W10185988 Timer - AppliancePartsPros.com
Eric
stringbender
#3 Posted : 10 years ago
stringbender
Eric thank you so much for confirming my suspicions. I have ordered the part I will let you know for sure if that fixes the problem.
