Zjac
#1 Posted : Tuesday, April 7, 2015 12:40:37 PM(UTC)
Zjac
My washing machine won't drain although it does spin. I called sears and they said it needed a new drain pump. They have the part here but before i order it i want to make sure thats what i need because I thought that i shouldn't hear it working or humming if it needs to be replaced. Could it be anything else?
Thanxs
sidfink43
#2 Posted : Tuesday, April 7, 2015 4:35:07 PM(UTC)
sidfink43
I am going to assume you have check the drain hoses from the tub and from the pump for blockage. Usually the machine will not work if the drain is blocked, so that is not likely the problem, but check again anyway.
See if you can use a meter to test whether or not current is getting to the pump when it is supposed to be draining. If it is then the pump is likely the problem.
If you buy the part from this site and it does not fix things you can return it.
Zjac
#3 Posted : Wednesday, April 8, 2015 4:36:24 AM(UTC)
Zjac
Well you give me more credit then i deserve. I've learned everything i know about washing machines in the last 2 days and there is nothing in the manual to help. I've been thinking there should be something like that that i could do but i can't find any direction. Can you advise? thanks
sidfink43
#4 Posted : Wednesday, April 8, 2015 4:40:59 AM(UTC)
sidfink43
I assume by manual you mean owner's manual. Here is a link to the service manual for your Frigidaire made machine.
http://www.emaservicetips.com/p..._TumbleActionWashers.pdf
Hope that helps.
Zjac
#5 Posted : Wednesday, April 8, 2015 10:20:27 AM(UTC)
Zjac
Thanxs for you help. I thought i had it all figured out. Found a quarter lodged perfectly in the opening of the pump. Put it all back together added some water and it drained fine but then when I did a full load I still had my original problem, the water didn't drain completely. Now what does that mean?
Thanxs
sidfink43
#6 Posted : Wednesday, April 8, 2015 12:14:38 PM(UTC)
sidfink43
Eithersomething is still blocking things or the debris has damaged the pump and it does not work at full capacity. Check the lines again and if they are clear try changing out the pump.
Zjac
#7 Posted : Sunday, April 12, 2015 5:40:02 PM(UTC)
Zjac
It did end up being the pump. Its fixed and I'm grateful for the help!
sidfink43
#8 Posted : Monday, April 13, 2015 4:11:43 AM(UTC)
sidfink43
Great, glad you got it fixed and thanks for updating everyone.
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 1/22/2018 9:47:40 AM(UTC)
Dishwasher won't drain (Dishwasher Repair)
by Drummabouy 6/22/2017 6:29:14 AM(UTC)
Washer won't drain (Washer Repair)
by jpowell1978 2/23/2017 5:58:30 PM(UTC)
Dishwasher Won't Drain or Run Cleaning Cycle (Dishwasher Repair)
by Katie L 8/4/2016 2:07:24 PM(UTC)
Bosch Dishwasher won't drain and goes directly to "Clean" Light (Dishwasher Repair)
by ed3120 6/4/2016 4:40:01 AM(UTC)
by brokenge 2/18/2016 2:32:59 PM(UTC)
Frigidaire dishwasher won't drain (Dishwasher Repair)
by kohanz 12/4/2015 9:35:55 PM(UTC)
Washer won't drain!!! (Washer Repair)
by Bdelay24 11/5/2015 6:27:01 PM(UTC)
Dishwasher won't drain! (Dishwasher Repair)
by Crafter_Man 10/12/2015 4:30:35 AM(UTC)
Top load washer won't drain... (Washer Repair)
by Gigler90x 7/28/2015 7:38:09 PM(UTC)
BAFFLED!! LG Washer won't drain. Drain clear, pump works. (Washer Repair)
by SimplyBaffled 5/18/2015 10:17:55 AM(UTC)
Washer won't drain (not lid switch) (Washer Repair)
by Cricket2 3/21/2015 11:26:37 AM(UTC)
Washer won't drain or spin (Washer Repair)
by garywool93 3/19/2015 9:40:02 AM(UTC)
